Paul64
- Jun 13, 2003
- Location
- South of France
- 1995 W124 E300 Diesel estate (250k miles), 2008 CL63 AMG, 1969 Triumph 2.5PI, 1975 Triumph TR6
Hi all,
I wonder if there is an adjustment to allow 'throttle-less' starts on my 300D 24v?
The car always starts, hot or cold, although it does take the tiniest amount of throttle to make it start after the glowplug lamp goes out - it almost feels like you're taking a small amount of slack out of the cable and cracking the throttle open a fraction of a mm but it's enough to make the engine start perfectly each time.
I would have thought that the fuel pump would have done this itself with a start-assist actuator - is there an way of dialing a little rack movement on starting with an external adjustment?
It's no big problem obviously as the car runs fine, but I do hear the Mrs try starting the car in the mornings and it either lumbers into life eventually without throttle or, starts with a stomach-wrenching increase in rpm if she pushes a bit too hard on the pedal, which doesn't seem right either....!
I look forward to hearing thoughts on the problem,
Paul
Paul
