w124 Difficult to start when warm?
badshot1uk
Orpington, Kent
1991 300 TE 24V Sportline, 2001 Chipped Picasso 2.0 HDI
Hi all,
As above really, Ive only had the old girl a week or two and shes consistantly got worse starting when warm, shes spot on when cold but crap (2 or 3 attempts) when shes warm'ish.
Any ideas as Im useless with cars useless!
Cheers
Paul:o
If you have the old BOSCH jetronic K system then it may be your warm up regulator or if its the later K-E SYSTEM then maybe your engine coolant temperature sensor is bust or disconnected. Other possibility is an inlet manifold leak.
Could be a vapour lock caused by low fuel pressure. iirc there is a one way valve near the fuel pump that can fail so losed pressure.
