RoundOzBenz
- Mar 31, 2014
- W124 E220
Did some repairs on the W124 door map pocket over the weekend. The pocket wasn't attached securely due to broken tabs. This caused annoying rattles and creaks every time I drove over a bump.
Thought I might share the methods used, some I did find in this and other forums. Cannot say methods used are 100% safe, but the length of screws/pins used was kept to a minimum, in case of a side-on collision.
After making these repairs, the map pocket is now held as solidly as a rock to the door. No creaking, no ratting after the test drive.
I drilled out a couple of the mushroomed pieces of plastic that had broken. I also drilled out various other tabs and inserted metal pins. For one of the existing tabs secured by a white clip, it still rattled so I folded some tape underneath it. It's pressed down permanently, so the tape won't fall out.
