Hi guys, my w124 E200 (m111.940) recently broke down, it suddenly stopped on the road as if I had run out of gas, it started up again after at least 10 tries. I took the opportunity to bring it home but since then it won't start at all! I noticed afterwards that the fuel pump no longer made a sound when I turned the key. So I first changed the fuel pump with a new one (it had trouble accelerating at high speed and climbing hills on the highway so for me it was logical that it was the fuel pump that was starting to fail ) but still impossible to start.. I exchanged the fuel pump relay with my brother’s relay (w124 E220, it's the same relay) his car started, not mine.. so it's not the fuel pump relay. And I can hear the *click click* of the relay. I recently changed the OVP to an original one but no change. I saw on other forums that you can force the fuel pump by connecting pin 87 and pin 10 of the fuel pump relay but on mine I don't have pin 10 (I would try to put a photo) I'm starting to have no solution, if someone can enlighten me.. thank you in advance
-Pierre
-Pierre
