lukebowman551
i've got a problem at the minute to do with the fan belt. I had a belt snap last week so replaced it. The belt had only been on about 6 months and was showing signs of wear on the back side of it. I have now replaced the belt but the back of it i definately rubbing on something already and it's only been on a week. In my opinion the belt is too tight, ie too small (the wrong belt). The tensioner pulley assembly is at full stretch, ie the damper is fully compressed and the spring is at full stretch. I think that the tensioner pulley is so near the crank pulley that the backs of the belt are rubbing against each other causing the wear. The belt that i replaced a while back was considerably looser.
Can you guys help? I think either the spring isn't doing it's job on the idler pulley assembly or that the belt supplied is the wrong one. My car is without air conditioning. When i pulled on the belt it is very very tight so i don't think it's the spring.
Have i been supplied with the wrong belt? has anyone heard of this before?
Any advice is appreciated.
