balge
checked the regulator pack. looked fine. 1/8 extening from bottom of unit. how do i check diode function!!
If the brushes are only sticking out 3mm they need replacing. New are about half an inch out iirc....You can get replacement brushes but I would replace it anyway for the price of a new one
If you have a half decent electrical tester it should have a diode test position, basically you need a low reading one way and a high reading the other way, diode is like a one way valve
