W124 fuel tanks
carat 3.6
In the workshop
S124 E300d wagon, W124 om606 monster, E46 v8 coupe
Hi guys,
anyone know if there is a difference between petrol and diesel fuel tanks in the w124 saloons? I'm going to be fitting a turbo diesel into my 300e over xmas, and wasn't sure if I need to change the fuel tank or just some of the fittings.
Cheers, s. :cool:
Thanks for the links,
Looking through the numbers 1244700304 is listed as a replacement for both vehicles with a 70l tank, but the fuel strainers have differing numbers.
It might be just the fuel strainer fittings that are different, I'll have a check in the week.:thumb:
They are the same. Dont forget to remove the fuel filter as the diesels have it located in the engine. U need to change the instrument cluster also
the fuel strainers in the tank are certainly different, the petrol one being more of a finer mesh. (i have cleaned/changed my diesel strainer many times, and broke a petrol 124 and saw the strainer that it had)
That confirms it for me then.:thumb:
I didn't want to pull the tank out only to find it was the same as what I was replacing it with. I'll get a new strainer from mb and fit that, everything else will come from the donor car.
s.
Thanks, I've got a fast diesel with a tired body and a slow petrol with a mint body, so going to swap everything over.
^ Thats always the way with these cars.. can never get one that's just right!
It's more about time for me now. Rather than doing a little bit here and there to each of them, I'm going to build 1 out of 3.:crazy:
I can only drive one at a time anyway.
