MB-tex
Hi All
I have a series of problems that I want to resolve. Car has been checked over by my mechanic who knows these cars and by an auto gearbox garage who also have experience of this model. They have both not been able to resolve the issue (partly due to my budget). I am having the car looked at on Tue by some sort of Merc specialist guru type that my mechanic uses so hopefully this will help too. But I thought I'd hit on the wealth of knowledge on this forum as well to try to get my car back to her normal lovely condition...
1996 w124 E280
Car is regularly serviced and maintained by A J Robertson in Hove. Currently running but with two issues as below.
Problems as they have presented themselves:
Approx 2 years ago the cruise control suddenly stopped working. Car otherwise ran perfectly with no other issues. Did not get fixed.
About 4/5 months ago I noticed the car’s idle speed became irregular when waiting at traffic lights etc…Very faint at first but now more pronounced.
During a recent long journey on the continent (Toulouse and back) this became a problem when the engine would almost cut out at times when slowing down for a roundabout and there would be a power lag when trying to set off again. This has become less of a problem now I use the car less.
During the trip on the continent the car began to stop changing up into 5th gear. At first it would be occasionally and it has now stopped using 5th gear entirely. The other gears seem to change correctly. The kickdown switch still works but changes from 4th to 3rd at highway speeds! The engine is on 3000rpm at 60ish mph. In 5th it was at 2500rpm at 65mph. Switching the gearlever between 5th and 4th has no effect (gearbox stays in 4th). When on highway I now stay at 55mph (2500rpm).
The car has no other issues I am aware of.
Have done copious research and know it is throttle body/solenoid/4th5th switch/deteriorating loom etc... but mechanics have not come up with anything definitive yet so was hoping the above symptoms might give a precise thing to follow up. Throttle body new from merc is £2000!
1996 w124 E280
