ash_2009
Dear all,
Car w124 e220, 1994
Today I noticed the following.
While driving for about 20-25mins in normal traffic I noticed the temperature gauge got up to what I think is 100 (see picture). It never went above that mark ever before but it did not come down as quickly as I expected to as I would have thought the fan would have kicked in and cooled it down.
This car has never had this problem.
Another strange thing is that when I got home and parked the car and left it to cool for about and hour the temperature gauge was now showing just above 80 C. I would have thought that in an hour this would have dropped below the 80 C mark but not 0 C.
I have checked for leaks - none
I have checked coolant level - perfect at max mark.
I checked for oil in coolant (head gasket) - noting (plus the head was done a little while ago)
I did the "carrot" test - this is where I am a little lost. Car off/engine cold I can spin the fan both directions freely no problems. Then I start the car (engine cold) and place the carrot on top of the fan blades and it is sliced
off but fan stops. Then got the engine nice and hot (80C) and again placed carrot and again top was sliced but fan stopped again. Lost lost lost.
Also for good measure I have removed the two fan switch connections which are under the black cover on the front of the head and gave a clean with contact cleaner. While doing this I by-passed the fan sensor with a piece of wire and the fan spins although I would have thought much faster!! Further I measured the volatage across the sensor and got a reading of 5.0V. The fuses were also checked and seemed fine.
So I am trying to narrow the problem down and I could be wrong but the three below comes to mind after reading several posts here.
1) Thermostat gone - replace??
2) Fan temp sensor gone - replace??
3) Radiator blocked - needs a good clean??
4) Viscous fan coupling gone - replace??
Any thoughts
Ash
Car w124 e220, 1994
Any thoughts
Ash
