Aug 9, 2012 #1 MBhowden Active Member Joined Aug 4, 2012 Messages 76 Location East Riding of Yorkshire Car 1993 220 CE My new W124 coupe has some rust under the washer bottle, what is the best way of repairing, can it be replaced easily? Rob
Aug 9, 2012 #2 coupe deville Active Member Joined Aug 21, 2008 Messages 784 Car 93 E320 coupe sportline facelift I cut the rust out and welded a patch in, then a good dollop of paint applied with a brush so its nice and thick. I ommitted the drain hole as I reckon it will outlast the rest of the car,I also put new seals on the washer bottle
Aug 9, 2012 #3 G GP801 MB Enthusiast SUPPORTER Joined Jun 18, 2010 Messages 3,203 Location Sussex and Tuscany Car 2003 W209 CLK, 2005 R171 SLK, Volvo XC40 P8 Twin Motor Pro EV Very common spot to go. Check the other side under the ABS thingy. Often find the same issue. Its not structural so a patch repair will be fine.
Aug 10, 2012 #4 M mercboiuk MB Enthusiast Joined Aug 3, 2006 Messages 1,782 Location Norwich, Norfolk Car 1995 E320 Coupe I had exactly the same area succumb to rust, too. Likewise, under the ABS unit. My remedy was the aforementioned cut, weld and paint as completed by my Indy. I started a thread on it HERE. About half way down the first page of that thread you'll find photos of the repair process HTH Darren
Aug 10, 2012 #5 coupe deville Active Member Joined Aug 21, 2008 Messages 784 Car 93 E320 coupe sportline facelift If you're going to have any welding done, disconnect the battery to protect the ecu's. Better safe than sorry.
