It was that nail biting time of the year again, and it nearly passed.... but not quite. It failed because the SLS pipes were badly corroded and leaking fluid. I have been told that to replace the pipes and do the job properly, you have to drop the subframe and you are advised to replace the brake and fuel pipes, when you are there.
As I need both my arms and legs (as I got told that was what it would cost to repair), the alternative is to do a dry conversion, and do away with the hydraulic suspension altogether.
Therefore my questions are.....
1. Was the SLS standard equipment on the 230TE, or was it an option?
2. What is involved in doing a dry conversion and is it a bit more than just
replacing the shock absorbers from oil to gas filled?
3. Has anyone done this and was it successfull?
Thank in advance...Sean
