hi, strange things are happening with my ce 220 1993.
i could not shut the sunroof from the raised position about 2 weeks ago so had to revert to manual closure. the motor was fine to slide the roof up until this point but when i tried to tilt it got stuck open.
today while checking a couple of other bits i decided to check all the fuses and give them a little fiddle to check for corrosion. i noticed later that the interior light and radio were not working so i checked the fuse again by just fiddling with them and the light / radio worked again. at this point i locked the car with the key and accidently turned it the wrong way which activated the windows and also the sunroof!!! the sunroof now works fine???
i had not touched the sunroof for 2 weeks and even ordered a replacement cable from merc.
anyone else had this sort of fun?
