romsey4
Hi all.
This is my first post since buying my 1989 300ce late last year. I have read a few threads on this topic but still unable to narrow down my problem. The car starts first time everytime, but when it reaches its normal operating temp it develops this rough uneven idle that fluctuates between 400-800rpm ish whilst in gear. This causes it to die sometimes when coming to a stop or changing from drive to reverse. Ive checked the idle valve and this is clean and operates when I put 12v to it. I can unplug the valve and the problem goes away but it idles to high at around 1000rpm. Also if I remove the fuse from the ovp it idles evenly but is still to high. Ive checked all the vacuum pipes and they are good. Would my next step be temperature sensors?
I would appreciate any advice
Thanks in advance
Thanks in advance
