Gian Piero
- Apr 9, 2013
- w124 300ce 24
Hello everyone, recently i bought a 91' japan spec w124 300 ce 24 with the 5 speed automatic transmission, it has a few problems most important were no 5th gear & the gas pumps were almost not working.
The engine runs very smoothly but when you accelerate it tries to stall & then it goes very strongly till 4k-5k then it has no power due to the bad gas pumps, however I just replace both gas pumps with bosch spares & now the car accelerate as before till 6k when the engine become completely powerless (the old m104 revs up to 7k or more)
I'm prone to believe its the distributor & rotor arm, because it backfires between 4k & 2k rpm without accelerate & when cold (lets say morning first start) it missfire quite badly until it warms up
Also the engine set on a low idle, when hot & in D it is around 500 rpm.
Any ideas what the problem might be?
I found an expert on 722.x transmissions & he will solve the 5th gear problem.
Many Thanks!
Many Thanks!
