W126 abs light
taj khan
Glasgow
Mercedes 500se
Hello all,
I have a 1989 w126 500se.
Problem is that the abs light is constantly on. When i start the car, its off, as soon as i drive it goes on. Brakes and disks are good so can either be abs sensor, abs ecu or abs pump, where do i start from ?..
The car brakes perfectly with no issues at all....
Can anyone help.
Thanks in advance :-)
I would have thought its probably your sensor. Bit expensive new but used would probably be fine.
Your brakes should be fine, the light is just telling you theres a fault in the abs bit, so dont expect your abs to work..
Thanks to all for your replies, Much Appreciated.
I have checked the fuses before and they are all fine. I think its the abs sensor.... Will start browsing ebay...
Would Euro Car Parts sell one and if so, how much would you think it will cost.
