My W140 doesn't like the cold. When its left overnight, it acts strangely about 50% of the time...
It seems to have difficulty choosing which gear it wants when its in Drive! When I go from R to D (as I reverse out of the drive in the morning), it can take a few seconds to engage D. As you go along, it doesnt change up as it should - it seems to get stuck in 3rd and wont go any higher. Now, I know that when its cold it holds the gears longer to warm up the cat etc - i'm used to that but this is different! After a minute or so, it will decide its in the wrong gear and go into the right one with a jolt, and after that its fine.
Now, if you select gears manually for the first minute or so, the gears engage fine and its perfectly happy. i.e go from R - 1, 1 - 2, 2 - 3, 3 - 4, 4 - 5. After a minute or so, you can just leave it in D and then its happy.
I've had the ATF changed and the filter (in the torque converter as well) and they reported that the ATF was very clean and there were no metal bits at all in the old stuff.
I'm thinking it has to be electronic, because the gears engage fine manually. And after the first minute, its perfect - gears change smoothly and correctly up and down. Its got 110,000 so I guess the gearbox could be buggered, but I'm hoping its something simpler (and cheaper !
Any ideas?? Thanks!
Any ideas?? Thanks!
