I have an ML 320 W164 05 model with 126K, auto. I love the car but there has been an intermittent limp mode fault that has now been joined by a check engine light and a P1402 code. The problems in order of there occurrence are as follows and this is what I have tried based on the advice of forums such as these.
Faults
1. The car starts fine, most mornings in full power mode. No matter how long the journey 5 mins or two hours it remains in full power throughout the journey. No matter how short the interval is between engine switch off and the second start it enters limp mode. Weather/temp makes no difference. The car can be stone cold or warm and it still starts in limp mode. The car drives fine through the autogears limiting around 2,000 RPM but is gutless compared to full mode.
2. For a couple of weeks we had an intermittent Check Engine Light that was then associated with the limp mode but now it is on permanently in and out of limp mode.
3. I bought a WIFI OBDII reader to use with an iphone (understanding this will only provide limited info), the only code is P1402 which if cleared does not take the car out of limp mode and returns with the CEL after 2-3 starts.
Action Taken
1. Following advice on other forums I cleaned the EGR valve which was not overly dirty. At the same time I replaced the air and fuel filters.
2. Lots of forums suggested P1402 and the limp mode could be fixed by replacing the DPF Sensor. I did this with an OEM part for £22 delivered. Sadly the CEL, P1402 and limp mode remain.
I suspect I am destined for a date with a STAR computer but before I do does anyone have any advice or ideas on anything I should try? Are there any other related sensors or checks I could do related to the P1402?
Many many thanks for your help in advance. David
Faults
Action Taken
