MercOffroad
Good day everyone
I have a 2007 ML500 and ran into a little problem. After doing some off-roading the dashboard suddenly went haywire after going over a bump. I have brake, ABS, ESP and a check engine warning light. Car is running perfectly fine otherwise. No engine or transmission issues and no limp mode either.
After connecting the trusty iCarsoft MB OBD it looks like the issue is with both rear wheel speed sensors. More than one module's error codes specifically mentions that both rear wheel speed sensors are not available on the can bus. I assume it might be wiring related since it's a tad bit unlikely that both will fail at the same time. I don't have any rear SAM issues otherwise all rear lights and everything else seems to be working.
I don't have much experience with DIY'ing the W164 so I'm looking for some advice. I already jacked up the car and removed the plastic covers on the driver's side (RHD car) and I don't see an obvious path for the wires so if someone can point me in the right direction it would be very appreciated. I'll also post the specific error codes from the icarsoft if needed.
Regards,
Regards,
