W168 P0303 Cylinder 3 Misfire Detected
TheJoker
Near Oxford, UK
A160 Petrol/Auto/2001
Hi guys,
Recently my 2001 A-Class (W168) stopped running on all cylinders. I took the coil pack off and couldn't see anything seriously wrong, and the plugs looked quite OK.
I've borrowed an OBDII reader (Sealey VS8700 - nifty little thing!) and it showed 4 codes, which I reset, and then I ran the engine for a while and the engine light came back on. There were two codes, both the same number;
P0303 - Cylinder 3 Misfire Detected
My gut feeling (and hope) is that it's just the coil pack :confused:? So before I go and order a new coil pack, I thought I'd run things past your immense knowledge. :thumb:
The engine runs fine for a moment and then degrades. In fact, I thought it was fixed after I reset the codes as the engine was running smooth as silk. Then when I increase the revs it starts spluttering and doesn't want to rev past something like 4,000rpm. And after some 4 minutes of running the engine light, with the aforementioned codes, came on.
Any thoughts!? :dk:
Thanks! :cool: :thumb:
Yes, the coil pack looks like this:
I've got Bert's tools to remove the cover, so I can pop it off and back on in pretty much no time.
I believe the coil packs are prone to break down, however, I just wanted to make sure there's nothing other obvious beforehand. :) Thanks!
Hmmm... which cylinder is #3? :)
I just wanted to say that a £46 coil pack from Euro Car Parts solved the problem. Runs perfect now. Easy thing to fix with Bert Rowe's ignition pack cover removal tools and two Torx sockets.
Thanks guys!
