divettri
Hi all, I had my vehicle serviced at my local mechanic. This included a new Air Filter. Since this service, the Engine Management Warning has been illuminated. I took it back to the same mechanic who plugged it into the diagnostic machine & the fault that came out was Mass Air Flow Sensor. They re-checked the Air Filter (which was ok), took the inlet manifold off & checked the Mass Airflow Sensor which seemed ok & also checked & cleaned the electrical connections for the sensor before resetting the fault code. They said to drive it down motorway for one junction & back keeping in a low gear as could also be related to DPF blocking. I done this & all was ok until just before I got home when the warning came back up. I took it back immediately & it was same fault, Mass Airflow Sensor.
What I am wondering is whether it is easy enough for me to replace this myself to avoid any more costs (have paid out a lot already)?
How or where do i get the correct part?
Does anyone have a guide as to how to remove the old & fit the new?
Ricki
Ricki
