W176 a45 stuck in germany please help
C19WKR
Scotland
A45 AMG
Hi all, so after driving from Scotland heading to the nurburgring, my car decided to throw up some fault codes.
C003700
U140B00
U041681
No abs
No tc
No power steering
No 4wd
No parking brake
I took it to the local mercedes once i got off the ferry in holland which was on the way here, they scanned it and said it was a rear wheel speed sensor, so changed that and cleared the faults
Drove down here and the codes came back again.
A few guys i spoke to here said it could be a break in the wire or need a hub.
Any help is appreciated
Might be a dumb question but.... does this mean that power steering etc wasn't working?
Or does it just mean that some false error codes were being displayed because of a fault in the error reporting system?
Obviously I'm leading into asking whether the car can be cautiously driven to your safe mechanic.
  • Like
Reactions: JHS
When mine went I had steering but it was heavier, still power assisted. Lost ABS and TC as well, turned out to be magnetic wheel bearing that generates the ABS pulses, not the sensor itself.
If possible swap the sensors to see if the fault stays on the same axle.
Yeah that sounds about the same as mine, cant find anywhere that has a bearing in stock before i head home
