Hi Guys,
I have a 98 C200 Manual, it has had the battery disconnected for a while and now It is reluctant to start, idle and rev. i have replaced the MAF, throttle body, plugs, coils, coolant temp sensor, fuel filter, crank sensor, fuel rail and pressure regulator, throttle position sensor and cannot fathom what the problem is.
once the car idles after a few failed turns over, it will back fire through inlet and then settle to a 1k idle, when i touch the accelerator the revs die and car cuts out. any advice is appreciated.
Kev
Kev
