-V-
Hello all, we seem to have developed a rather worrying fault with our W202 C200 Elegance (2.0 automatic)
The car starts fine but as soon as you pull away (and reach a certain speed?) the ASR and BAS lights appear on the instrument cluster and the car completely bogs down.
At this point the car will not go any faster than about 20mph no matter how much you press the accelerator pedal. When you turn the car off and on again, it is fine until you again reach a certain speed where it will go into some kind of limp mode. I must point out that the car does not stall or cut out.
We've tried to press the ASR button to turn it off but it does absolutely nothing.
The car is at a mechanics and they have supposedly plugged it into a diagnostics machine but nothing more was said after that. Correct me if i'm wrong - but doesn't a diagnostics machine usually tell you exactly where the fault is? The garage can't figure out where the problem is.
Does anybody know where the fault could be or they've had something similar happen to them? Is this likely to be an electrical fault?
Everything else on the car works fine apart from this fault that seems to be overriding the normal driving conditions.
If anyone has any ideas, I would be more than grateful if you are able to share them.
Thank you guys!
V
Thank you guys!
V
