tron
The 722.6 5 speed automatic is adaptive and if you buy one that has been used by the archetypal little old lady, it will be in top somewhere around walking pace. This means that if you kickdown, the shift is lazy and it goes from fifth to fourth without arriving anywhere near a useful point in the torque curve.
A transmission reset is a jolly good idea and it transforms the car. I know, I just did it.
For those who don't know how to do it, it goes like this:
Everything off.
Key to second position. Do not start the engine. Depress accelerator pedal fully to kickdown and hold it for fifteen seconds. release the pedal and switch off.
Wait for three minutes without operating anything. Don't open the doors or operate the interior lights, radio or anything else.
After three minutes, the transmission is reset. The next time you drive it, it will adapt in accordance with the first forty shifts. If you glide along climbing up through the gears and backing off, you will get economy at the expense of performance. Use a little thuggery and you will have it set up to pull away much more strongly and the kickdown will be faster and you will end up with a good bit more go. My 250TD now behaves as though it has a T!
Everything off.
