I was at my parents house again yesterday and spent an hour on the car.
This time I came prepared with a mini hacksaw. I put some masking tape on the fuel line to stop the saw slipping and painfully slowly managed to cut out the section of rusted line.
I'd done some research and found the steel lines have an 8mm diameter. So I had bought some fuel injection rubber hose with a 7.6mm internal diameter to slip over the cut ends after they'd been deburred. I put double hose clamps on each end and... tada... all done. I fired her up and she started with no leaks
Uploaded with ImageShack.us
That is one end of the repair. Inspecting the corroded section of pipe I can see there are 2 pinholes where it has rusted through.
I ran the engine up to temperature and got ready to tackle the sump plug bolt. This time rather than attacking it from the ground I'd borrowed some wheel ramps so had much more space to work in. I used a 2ft breaker bar and tada... came of no probs. I changed the oil, filter, drain washer and o-ring.
So it's almost ready for an MOT I think. The only issues I can see are some rust on the undercarriage and 2 spots of rust on the brake lines. I'm going back down in 2 weeks time so will wire wool the spots of rust and treat them with something, then take her for an MOT and see what happens
Thanks for the help guys.
