JC180
- Jan 9, 2007
- Location
- Manchester
- 2010 Mecedes Benz C250 CGI Sport Auto Estate
Hi All,
This has been bothering me for a while but I have thought it a feature of the car. The roads around my place are dreadful and my car shakes a little and creakes over really broken ground, this could just be normal tolerances of body flex especially in an estate but I wonder if it could be something else suspension wise?
Secondly the steering creakes when under load, particularly bad when cold but is apparent all day. (P/S Fluid is full) Could this be due to a low idle (600rpm) which is not powerful enough to work the pump to its full? It sounds like it might stall when on full lock.
Thirdly when going over road humps the dampers really squelch, an indie has told me that the dampers should last the life of the car and unless leaking (which they are not) should never need replacing but I wonder.
The car has done 86K (FMBSH) and has not had the drop links done since 42K, would a few suspension changes (dampers, drop links, bushes etc) drastically improve things? The car could do with being a bit more refined around town I feel.
Any views knowledgeable folks?
Cheers
Jacob
Cheers
Jacob
