So iv finally had the time to make some headway on the timing chain of my sport edition c180k.
I have removed the s/c, alternator, aircon, PAS, and water pump, and crank pulley, along with the upper timing cover.
Also managed to remove the engine bay wiring harness and have all replacement parts on order from mercedes at a cost of £1900, including wiring harness, upper and lower chain, tensioner, guides, crank sprocket, cam adjusters and a few other misc parts.
Next up I have several questions for the community. Trying to source the chain breaker/riveter for the m271 engine for a reasonable fee. The lazer tools one looks great and is probably the best option but I cant really justify over £400 for a tool I will likely use once. Im finding a lot of kits that are listed as compatible but further down say "m271 with additional parts" but do not list the parts or offer them for sale. I have found the CTA tools 1095 set which doesn't list m271 as compatible, just says single and double row benz gas and diesel engines. However listed in the pdf available from the manufacturer it they have the anvils listed as oem number 271 589 01 63 00 which I believe is the part I will need?
Also I have read through the documents from WIS kindly posted on this and other forums by helpful members, regarding replacement of the timing chain. All of which show a "wedge" that comes in the timing kits cheaply available online, but do not show what or where they are to be used?
Any help much appreciated as I am unable to make any further progress removing the front timing cover until I have the chain broken and the cam adjusters removed.
Pictures below for attention.
