pangster
I'm having some issues with my car. When I attempt to start it in the morning - it takes quite a few seconds of cranking to get it going and once it eventually does kick into life there is a strong smell of petrol. The car will drive ok (once it's started) although when I try to accelerate from a cruise it feels as though there is a distinct lack of power. Everytime I shut it off and go to start it again 9 times out of 10 it is the same drama. Cranking for 5-10 seconds and then kicks into life. Battery and starter are fine as is the EIS as that has just recently been changed and these were all checked over by the MB dealers. I've had it on generic a code reader at my local mechanics and there is no codes or pending codes associated with it.
Having searched the forums - I'm lead to believe it is likely to be one (or all :roll eyes of the following:
Camshaft position sensor
Crankshaft position sensor
There are two camshaft position sensors on the engine (intake and exhaust) - is it common for one to go more than the other?? or are they both likely culprits?
Does anyone know the part numbers for the above??
Thanks for your help in advance!!
