MrGreedy
Any chance you could share that part number please?
It was 4 years ago, so I'm struggling with my failing memory I'm afraid.
Two options. I suggest you try both to confirm.
I've just gone on to the ZF aftermarket website, put in the reg (it's the 3.2 V6 engine) and it shows the Sachs number as 553 870 for the rear shocks. That sounds familiar and the pictures look the same as what I got, but that is now superceded and no longer manufactured. Replacement part number is 317 268.
Some 553 870 shocks are available, but they are considerably more expensive than the 317 268. RTG Automotive sell them on eBay currently for £46.75 each. Not too bad. Autodoc for £48, and with the volumes Autodoc do, fakes must be a very low probability.
The other option (probably more certain) is to get your VIN number and go on 7zap, and do a VIN search. This will pull up your model and usually when you click through to chassis, then suspension, then shocks, it will only show you the shocks (or whatever other part you're interest in) that were actually fitted to your car, and any replacements due to NLS (no longer (in) service).
Take a note of the Mercedes A number, and put that into a website like Autodoc, and you will usually find a good few options for replacement shocks. You can do this to find OEM style spare part numbers e.g. Lemforder for loads of bits for your old cars. Has saved me a fortune!
I went with Sachs because they were what were originally fitted on the car, but with Merc part numbers instead of Sachs numbers.
Good luck.
