I'm pretty sure that the gear selector module on my 2003 C class cdi estate is playing up.
I have done a code read and cleared what I could using a Bosch generic reader, codes I could not clear include P240C (x2) signal from selector module not plausible.
Started by sticking in high gear, then low gear, display often does not change to correct reading.
status at moment is after checking all the usual reported faults (grounds etc) the car drove fine, all functions working well, stopped for a hour, reversed out and in drive was jammed in first gear, tried key off resets several times (normally works) but after 20 attempts I gave up and drove 1 mile in low. placed in park while I opened the gates and it would not pull away in drive, just revved. after a few gear selector movements and a couple of resets it managed to go into gear.
there's a few on EBay including one with the same part number
2032676024 also a few with the last 4 digits are different, they also use a 5 digit number rather than this number but I dont know where that comes from??
Any help with symptoms or part numbers much appreciated, one advertiser didn't give a part number as he claimed they were all the same..
if the trans is scrap so is the car.
Based in Herts not far from Watford so any independent reasonable trans experts recommendations appreciated. I have rebuilt a few transmissions both auto and manual in my time so can do a bit for myself..
thanks for any help
Sam
thanks for any help
Sam
