Jigglyjohnson
If i was you i would remove the drivers seat and then remove the front and rear carpet sections and get a good electrician to check the wiring as there are spare parts available for the loom pins plugs etc from mb with out the need for replacing the whole loom. Which would save a few pounds. They should be able to trace the source of the leak quite easily if you have that much of a bad leak into the cabin. Ive seen a few 205 with water ingress and 8k for repair seems high take it they are quoting for a whole loom replace not a repair ?. Main causes of leaks on these models are a/c drain under the heater box middle of the transmission tunnel not fitted correctly but will only over fill when a/c being used and yours was parked up. The windscreen bonding has failed and allowing water into the car have you had a windscreen fitted last 12 to 18 months ? Takes a while to notice any electrical issue sometimes. This was a comman with rush fitters. Then the main loom grommet under the drivers dash area can be seen with the carpet out this wasnt fitted correctly and water build up in heavy rain and it trickles in behind the sound deadening and into the o/s of the car and sits in the osr area get these checked out
