KorkyBoy
My soft top won’t open -Advice please :
When I unlatch it, the windows go down & the switch illuminates ( steady) but the rear window ( bow?) doesn’t “clunk” to unlatch. Pull switch to raise roof but nothing happens & switch flashes.
I’ve checked that the boot is closed & that the soft top inner compartment cover is closed - microswitch “clicks” when lever is pushed manually but haven’t checked if the switch is sending the required signal.
I’ve tried to reset the roof sequence as per the owners handbook ( ignition to 0 then 2 then depress switch) but again no result.
Headrests rise & fall by their own switch but sometimes they go up instead of down when I unlatch the roof ( which might point to a sequencing problem ?).
Have tried to open the roof manually ( in an attempt to operate it through the sequence a few times to reboot the sensors) as per owners handbook using manual closure instructions in reverse ( release hydraulic pressure by turning screw through boot hole, then unlocking the soft top cover with the special spanner) but I can’t get the bow to move .
The car had been in winter storage - battery was flat but was charged & car started - I cycled roof once - it worked fine) - then a week later it moved a fraction then wouldn’t go further - Closed it via the switch , then it refused to work again.
Any thoughts or fixes please ?
PS - I’m a one star mechanic - will do simple tasks but anything too complicated & I’m out of my depth .
