W210 E55 injecter removal
amg3.6
UK
C55 Amg White W202
Guys all wiring removed bolts are off the fuel rail but neither injectors or fuel rail is coming off? What am i missing?
Lift the inlet manifold off with the fuel rail attached
Hi justin the inlet manifold is off together with injectors and rail. I need to take off so i can split the manifold.
They are very tight. I use a small lever and lever them up gently.
I got the fuel rail off but still couldn't get the injectors out so i used a small 8mm socket with an extention bar on and tapped them out. All are out now.
