- Jan 3, 2013
- AUDI S8 V10, S210 E320 CDI (R.I.P.)
Can you post up your vin number please or PM if you prefer
You can have the VIN if you wish grober but I have finally solved the problem I think!
I disconnected the duo valve, fuse still blows
I disconnected the circulation pump, fuse still blows
M55 disconnected again, fuse still blows
Then after a lot of head scratching I thought I'd check again. I remember that the car was fine for a day and then I had a loss of water. The pipe on the top of the EGR cooler blew off, mainly because the clip was not on the pipe but just on the hose (my fault). So I checked everything around this area again and there is a connector that plugs into the top of the gearbox (or back of the engine). Connector removed, sprayed with contact cleaner, blown with air and reconnected. FUSE DOESN'T BLOW! I managed to connect STAR to it and cleared all faults. i have attached pics below of the connector and the possible fault (which I couldn't read at the time).
Thank you again for all the replies and help, I hope this thread will help someone in the future.
