I have a w210 E280 which has developed a knock in the suspension when I turn left while moving. It appears to come from the right hand wheel area. Any suggestions?
Weight transfer will load up the OFFSIDE front suspension when turning left. You probably have a broken front spring but get it checked ASAP since the spring perches on these cars have been known to fail prematurely due to hidden corrosion. It might just be an antiroll bar bush or linkage failure which is not critical but best to get it checked up on a ramp at a reputable specialist.
