IanT
I've searched but this is all I found...
http://mbclub.co.uk/forums/showthread.php?t=7143&highlight=towbar+wiring
OK, I'm going to fit my genuine MB towbar, possibly tomorrow. The electrics question bothers me a little. I reckon I should be able to make my own bypass system either by wiring in FETs or FETs and relays between each bulb connection and the trailer socket.
I have a socket, some wire and will buy FETs if that looks like the way to go.
Looking at it logically, there should be no more than 2A drawn from any pin on the trailer connector, so FETs alone should be sufficient to supply any current required without using relays, plus they won't draw any current from the car loom.
I've had some other ideas too... if the bulb failure system places low voltages onto each bulb to test it without lighting it then I could use some CMOS logic to provide a hard switching level above the voltage that will cause the bulb to begin glowing.
So, am I on the right track, or should I just go out and buy a ready made system off the shelf?
Ian.
Ian.
