W211 atf change
MIZEEKS
W211 2007 facelift
My 2007 W211 (E320 cdi Avantgarde) with 7G Tronic last had fluid change 30/12/2011 @ 41672 miles. Now @ 67500, when should ATF be renewed?
Also, Plugs were changed at same service -when do I next replace them ?
Thanks.
Mike.
I have the same model but a Diesel with plugs? I think not ! Unless you actually have a petrol engine
ATF should be done roughly every 40k miles
By plugs I take it you mean glow plugs. They don't need changing unless they are faulty, which should be indicated by the light remaining on/coming back on after start up
Oh, and the ATF should be changed every 4 years or I think about about 40 k whichever sooner, yours should be changed as it has been over 5 years since the last change
