W211 Bi-xenon Headlamps Adjustment?
Surrey
E 220CDI Estate
Is it possible to adjust my bi-xenon headlamps? They are pitched just a little too high. (No, there isn't an adjustment wheel alongside the light switch).
They were adjusted at the first service by MB, but now seem to have crept up again.
The headlamps will be electronically levelled and can only be adjusted using STAR in conjunction with the usual MOT testing rig
The headlights can be adjusted in the normal way, using the little knobs on the top of the headlamps. Star is only required for the self-leveling function.
Correct, but you still need the MOT testing rig to assess that adjustment. Star is required to set the zero position of the self levelling function.
