No, not yet, but plan to, hopefully this week. Is that now the most likely thing in your opinion?
I have the exacts same issue with my w211 e320cdi. Initially i thought it was the engine but now I'm suspecting something else. if I hold the accelerator pedal at a constant pressure the oscillations increase to such an extent the car feels similar to driving over cobble stones. It isn't a whell balance issue as it is rev induced rather than speed..
An update:
Thought id try something today and was interesting.
Same 40mph speed, but used the speedtronic crusie control and guess what? It doesn't happen.
So, I presume that rules out dirty injectors?
What about MAF or auto box? seems odd I know.
Have you recalibrated the pedal module thingy? IIRC it's something like ignition on, press accellerator to kickdown, wait then release slowly but I'm sure someone will be along in a minute with the correct procedure!
That doesn't work.
I have proved it with my Star.
It is supposed to re-set the adaption data in the 'box.
As far as i know, it doesn´t modify the autobox adaptation, but the linearisation of the throttle pedal. For example, if you drive lazily with light throttle, the ECU makes the pedal more and more unresponsive: you have to push much further to get the same output. If you cane around a bit, the ECU uses a sharper response curve for the pedal so less movement gives more effect. If one stays in "lazy mode" too long, it takes ages to get the responsive mode back, and hence the reset can bring something.
Essentially it´s like how the Sprintbooster works
Regards
Matt
