jeremy156
I wonder if anyone is able to determine from a video clip what might be wrong with my car.
There is a lot of vibration in the engine which leads to the air filter enclosure and the intake hose to resonate. I have made a big improvement to the noise by taping up the join between the hose and the box as you'll see with gaffa tape and some draught excluder strip to take up the gap, yet there is still a distinctive low frequency buzz/boom from the engine. Sometimes it's quiet (as per the fisrt half of this video) and other times it'll be intrusive even when driving with wind and tyre noise.
After I rev the engine in the video clip you can see the hose and filter housing vibrating quite clearly. I can't figure out how the box itself it attached to the engine, whether a bush or grommet needs replacing perhaps. I'm inclined to assume something is wrong to cause such vibration and that changing the engine mounts would simply be to mask the problem - any opinions?
http://www.youtube.com/watch?v=4uCzgS5ObE0
