boxer 01
- Oct 23, 2009
- w211 e320cdi sport g7 with paddleshift
Post in thread 'Rear coil spring callculation' Rear coil spring callculation | Wheels, Tyres, Brakes & Suspension
Good advice. What I don't want is the car height too high are too low, I have seen that after fitting new springs the car becomes considerably higher, even when springs purchased from MB. The shockers I can get no problems, and I don't really want to go down the second hand route unless they are off a low mileage car and there aren't many of them now. I've had a look on the parts catalog but again it lists 2 types of spring for rear same part numbers, and 3 for the front again same part number its all about the colour markings.
I understand where you're coming from but for the price I think I will be getting new ones maybe eibach or Bilstein springs and trw shockers, and yes I have seen the adjustment slots. Thanks. I've asked a friend who's got a similar car to check his colour markings on the front and I am taking a rear wheel off later in the hope of checking colour markings on mine, I know for sure there are no colour markings on the front as they were fitted in my absence, I don't even know what make they are.Do you not think springs on a higher mileage car would of been changed . You can see by the condition if they are newish or not . You also need to count which slot the cup ring is sitting in on the shocks you remove from the car . Altering it's setting determines ride height.
What about any decent make spring from Autodoc that says it’s for a Sport E class , provided you match the description with the front and back they should be fine ?Good advice. What I don't want is the car height too high are too low, I have seen that after fitting new springs the car becomes considerably higher, even when springs purchased from MB. The shockers I can get no problems, and I don't really want to go down the second hand route unless they are off a low mileage car and there aren't many of them now. I've had a look on the parts catalog but again it lists 2 types of spring for rear same part numbers, and 3 for the front again same part number its all about the colour markings.
I was lucky that I had original colours on my Avantgarde so a careful read on Autodoc allowed me to match Sachs springs .
I would bet that different colour dots on a spring for the Sport model would have almost no difference between them , especially when you car suspension (parts of it ) are from 2007
I might just phone MB again tomorrow use your strategyI used autodoc . I matched the shocks part number to my chassis , I then went onto eBay ,searched for the same part number , spotted a few legs using the same shock and I got my paint markings via this process. I did use a bit of nouse as well calling the mb parts dept saying I think my car has the wrong springs fitted can he double check my paint markings , I gave him some balloney colours and he said , oh no you should have 2 yellow 1 green.
Same set up was used on the w219 and parts for those went to 2010 I think. Also worth a search .
What colour markings were they pleaseI had Mercedes supplied front springs fitted to my W211 2008 Sport and were under £60 each from the dealer.
I have no idea, sorry . My independent ordered them.What colour markings were they please
Just got it in time I think, the paint is peeling off. The colours are blue and green on the rear.View attachment 141745
That wont work on my AMG , way too stiff . remember that working on older cars that my dad would be buying decades ago.Yet when I push down on each corner no bounce at all. ,![]()
The ride height cup is usually on the spring , the shock does not control ride height.Yeah the sports springs have around 2 loops less . Avantgarde touring springs sit even lower , so he probably fitted classic springs .
Alot of places fit new shocks and don't even know about the height adjustment ring ,hidden beneath the cup.
It's because they probably don't know the answer. I must say some of our members on here are oversimplifying (which admittedly should be quite simple) an utter minefield when it comes to buying springs and spring pads for MB cars.Does anyone know the correct colour markings for a w211 e320cdi sport 2007 front coil spring. Mercedes won't tell me![]()
I was still the owner but I was not in the country when it snapped. I believe the front springs that are on are wrong because the car is higher at the front than the back and the diameter of spring is only 13.2mm.It's because they probably don't know the answer. I must say some of our members on here are oversimplifying (which admittedly should be quite simple) an utter minefield when it comes to buying springs and spring pads for MB cars.
Remember if you have not owned your car from new you can not really rely on the spring colour code , unless it also has an MB p/n alongside it.
Did the last owner get it right if/when he replaced the springs ?
