I have a W211 2004 E320 Cdi estate with 200k on it. I have owned the car for 3 years now and the problem has been very occasional but now daily.
The car when cold drives fine but when the engine gets up to temp the gearbox nearly always stop changing up unless you red line the engine, if revs drop below 2700rpm then it changes back down. On motorway drives I cant get out of forth unless I do 120mph
I suspect its the transmission plate(A1402701161) and my local specialist has 10 of those on the shelf(it must be very common). I have been quoted £500 for the repair, is this about right?
Its also due a D service, is there any way of checking what items need to be replaced? I was thinking of going to MB/Specialist for the A service and then getting my local garage to change other parts.
