W211 HID not working
mollymac
MB W211 E320 CDI sport
Hi
I have a RHD ( UK based) 2006 E320 CDI sport with what I assume are factory-fit HID Headlamps. DS1 35w Phillips Bulb and Ballasts
The drivers side dipped headlamp is off permanently. I have swapped the bulb and base unit ( I believe this is referred to as the ballast) with the working side but that still doesnt work so I have eliminated the bulb and base unit. I have tried locating the fuse but it doesnt show on the MB Fuse diagram. I then assumed the fuse would be located in the engine compartment fuse box ( as MB do not show that in their fuse chart) but all those fuses are Ok.
Also the ballast unit on the non-working side does not locate within the headlamp unit with a solid twist and click as with the other side
Can anyone help ?. Just so you know I am not that technical
Thanks in advance
Paul McG
It probably isn't the fuse...or both sides would be out.
When this happened to me it was broken earth behind the lamp unit on that side.
Many thanks
I will check the earthing and keep you posted
What was the solution?
Could be a fault with the front sam unit, which is located under the passengers floor. Had one go on my car.
