amazighman
- Apr 22, 2016
- CLK 430
Hi all
ABS light on my W211 2003 Estate is on , changed sensor and reset but it came back.
I presume the Impulse ring is shot.
I ordered a replacement , but would like some advice in regards to Airmatic bellows , do they need to be deflated or disconnected from bottom wishbone in order to remove the CV joint from the hub and to avoid damage to the air spring?
Cheers
Cheers
