Hi guys. So the left headlight lens cracked. PHOTOS
I found this replacement lens and messaged the seller, be he replied in broken english that it will not fit. I think it will, cause it looks the same. What do you think?
2nd option is to replace the whole headlight unit, but would rather change just the lens if possible.
I did some research and it seems that I need to remove the front bumper to remove the headlight and then either put it in the oven or use hot air gun to soften the adhesive and remove the lens. It seems it is quite tricky to do.
Any other options?
Any other options?
