Thank you mate for your input I’m really grateful so you did yours yourself with zero issues ? My good friend is actually a mobile mechanic and has said he would happily do the job for me on the drive is this definitely a job that can be done on the drive ?yes yes.. off that has to come.. did mine on the old clk, got a second hand rear subframe that was in excellent condition, removed the bushes etc and had it blasted and re coated.
The brake pipes were a little bit worse than yours and I bought everything to replace mine back to good pipe, I got the best fittings I could and anti corrosion pipe.
Spent a couple of hours on each one getting things cleaned, coated and bent into shape and fitted, it was quite relaxing.
If its not something that you want to do then yes the guys at Avantguarde are high on my reccomendation list, steve and the guys there know thier stuff ( I was drooling over the two mclaren slr's they had in when mine was in).
Give them a call and tell Lee that the guys at the forum told you to go there!! Steve does pop in here from time to time also.
For me if one is bad then the other will not be far off, get them all checked and changed if need be.
I haven't had any issues with the cls since i stripped it all down and rebuilt it, spending this weekend putting new front discs and pads on, cleaning the link arms and wheel well's while they are off and give it all a check over.
What about bleeding the brake system after the work has been completed etc I’ve seen some threads where it’s apparently not so simple to do on these cars and needs the star system to do it properly ?
Yes Steve was fantastic last time i used them a few years ago for a gearbox service on my old S212 and I did actually email them last night for a quote he replied today and stated that he would really need to see the car before quoting etc to see if the subframe needs to be dropped etc
The only issue with doing that is that it’s a 2-3 hour round trip for me just for a inspection so I’m not sure if I should just let my mobile mechanic friend do the work for me if you definitely think it’s a job that can be done on the drive ?
