- Feb 22, 2010
- Location
- Stirling, Scotland
- E55 AMG W211, E250 Sport W212, (and some Imps)
Did one of the springs today but got called away so couldn't manage them all.
Few things of note.
The WIS for the W212 says to just use the Telescopic Spring Compressor to remove the spring.
Struggled to get enough clearance and the tool would foul on the top of the chassis.
After messing for a bit decided to just do the same as for the W211.
1. Compress the spring.
2. Remove the shock lower bolt
3. Remove the drop link lower bolt.
4. Loosen front bolt spring arm to wheel carrier.
5. Remove rear bolt spring arm to subframe while support arm on jack and lower.
For the sake of 4 bolts seemed much simpler rather than struggling with the limited space and the tool.
![20201110_160325.jpg 20201110_160325.jpg](https://forums.mbclub.co.uk/data/attachments/78/78217-3310618b882c09797e888ed045c8ca98.jpg?hash=MxBhi4gsCX)
Bottom shim was almost rotten through!
Few things of note.
