W213 headlight wouldn't turn off (yes, off!)
Proeliator2001
W213 220d AMG P+
Driving to work in rain today and after about an hour I got two warnings come up. Intelligent light system inoperative and at same time a lamp symbol with Right Hand Dipped underneath. Thought that right front light had failed. Pulled close to car in front whilst waiting at lights and all my lights looked fine in reflection of their boot. Tried main beam and only left side got brighter. Okay I thought, I can live with that and get it sorted at my leisure.
Only later, when I switched car off and got out to look at front, the DRLs were both on but the right main light was also fully illuminated (two DRL strips, two smaller light units and the main headlight). Didn't matter where light switch was it remained lit. Locked car and waited for delayed lights to go off. All other lights went out but right hand unit stayed fully lit on dipped mains. Never known a light to fail on before. Imaging it would have drained battery bloody quickly.
Went back to check an hour later and light was off. Turned car on and faults had cleared and all was well. But saw both front lights have fogged up on the inside. Clearly moisture inside them! Not great on a near new car.
Booked in with merc tomorrow to look at that and a long list of other niggles. This if now the least reliable car I've had in 15 years although they are almost all electrical or trim related thankfully.
Car needs new headlight control unit. Not sure that's the issue. Both lights still have noticeable patches of condensation/fogging that I'm sure isn't normal. Anyone else get fogging of their full led headlamps?
W213 Headlights
Not had this problem but I'm not sure which way to set up the (adaptive) head lights.
Handbook says Dipped Beam Left Traffic or Dipped Beam Right Traffic.
Does this mean for a RHD car the setting should be Dipped Beam Left Traffic?
I've just changed from a Night Edition where the lights on that worked fantastic, at present I'm getting a lot of cars flashing me at night
It's the worst terminology I've ever seen. From memory it means what side of the road you're on, rather than other traffic, so yes, in UK it's set for left hand side.
If you're getting flashed, I'd recommend asking for the headlight control unit to be looked at or replaced. Since mine was done, I've have zero flashes where I was getting several per trip! The lights are much more animated and look more precise too since the change.
