Done all mine. By rear part you mean the rear centre console with the slatted lids? From memory there's two bolts inside the armrest cubby and one at the front of the large rear compartment. Pull up like you really mean it at the front to detach it from the front console and then disconnect the wiring underneath before lifting the whole thing out and then disassembling from underneath. To remove the dash panel you first need to remove the passenger side and centre air vents, both removable with proper or DIY coat hanger pullers, the passenger ones are buggers to get out and is why you'll see nearly every one on ebay has one of both clips broken off. Then remove the instrument surround which is most easily done by flexing it up at the bottom to clip a clip and then getting your finger nails into the gap and pulling straight forward. In the resulting holes you'll find the six screws holding the panel in. Once you got it partly out you'll need to detach the cables for the aircon controls before you can remove it fully. Be warned, brackets the screw go through are quite sharp metal and you could easily scratch the pleather or any plastic trim pulling it out.
