nadeem
- Jul 22, 2007
- E320 CDI Avantgarde 02
Hi Guys,
ESP fault,
C1102 Left rear wheel speed sensor : open-circuit, loose contact, plausibility Verify the internal resistance from the wheel sensor - While IGNITION = OFF : 0,6 - 2,3 KOhms Verify also the wires and the wheel speed sensor. Verify also the insulation resistance : While IGNITION = OFF : > 20 KOhms.
Replacement ordered... Remove the old one both ABS sensor connector and car wire harness connector perished... The new ABS sensor will have its own connector, however as the car connector is no more (bare cables black & black yellow stripe) how do I go about repairing the harness, is there a repair kit or do I need to replace the entire ESP wire harness of the car?
Found a connector in the grommet part number - 0305455928, not sure if this belongs to the car harness or ABS...
Please advise
ESP fault,
Please advise
